iPod 5th gen with iPod Classic motherboard?
are 5th gen components compatible with a classic mother board? Because my 5th gen mb was damaged and I want to replace it with a classic mother board.
Thanks
Bu iyi bir soru mu?
İptal Et
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
İtibar: 1
Thanks
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınSon 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,077
some are and some are not, depends on which components you are referring to. The HDD for example is...but you will need a different cable.
oldturkey03 tarafından
@oldturkey03
Thanks for responding!
Ok it seems the touch wheel works but the main component in question is the video display will that work? Also I assume the hold switch will work so the hdd will require a different cable? i have a zif ssd that I am using do you still think i will need a different cable?
thanks
ciscx85 tarafından
The display is different and slightly offset, this will cause your connection to not be properly seated.
