Ana içeriğe geç
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 Soru Tümünü görüntüle
Need Resistor Value for Dualshock 4
I accidentally broke this resistor while soldering new Joysticks on another controller and I was wondering if someone knows what value it has or what i should search for to buy a replacemnt. (Tbh I do not even know if this is a resistor, or what kind of component this is, so if you could tell me I would be very thankful)
Thank you for your help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
That's a capacitor. Obviously you don't have a multimeter. If you have a pal with one get them to measure it and order a replacement online, ebay etc.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Thanks a lot. I tried to measure it with a multimeter, but I was not able to get a reading, I might have done something wrong, or maybe my multimeter is just not fine enough. If you or anyone else could find the value before me, I would be very thankful. If you can not I will anyways try to use one of my universities multimeters, they might be better than mine.
Thank you again tho!
tarafından
@xtreefull Just a question: You did have the multimeter in the capacitor measurement mode, and the probes in the right two jacks? Most semi-decent and up multimeters should be able to measure at least in the lower hundreds of pico farads. Your best hope is an LCR meter in capacitor mode. My LCR meter measures stuff even my Fluke won’t do!
tarafından
@xtreefull
just to add to what @geirandersen has said, you can also get capacitance metres for a fairly low price, also you could use a donor board if getting hold of a multi metre is a trouble:-)
tarafından
Yorum Ekle
Yanıtını ekle
XtreeFull sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 153
