Ana içeriğe geç
2 GHz Core Duo işlemcili Model A1174 veya 2,16 ya da 2,33 GHz Core 2 Duo işlemcili Model A1207
Mini PCI-e SSD for boot?
iMac has a Mini PCI-e slot, occupied by the wireless card that can be used for other purposes such as additional SATA ports.
This got me thinking. There are mini PCI SSDs. Can I use this slot for an SSD? Anybody know if it's been done yet?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
this is a great questions... i have been trying to research this issues for a few hours now. so far i found two individuals who have said it is not possible. however, i intend to buy a mini pcie ssd card and attempt this procedure myself. (imac 24" 2.8ghz).
Update
FYI - Here is a link to someone who claims that their 2008 imac was able to read a mini PCIe SATA SSD: http://forums.macrumors.com/showthread.p...
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
ah you are my hero! I will wait for your news! keep us updated
tarafından
So it seems there are interfaces which are physically identical to mini PCIe, however, differ electronically. For example, mSata can be had in the form of a PCI Express Mini Card-like connector, however, electrically it is SATA. So, unless the mini PCIe slot in the imac is wired as mSata (which it most likely is not - working to confirm this) than plugging in a PCIe mSata SSD will be fruitless. However, there is a RunCore Mini PCI-E PATA SSD which could possibly work and possibly others... looking into it within the next few days.
tarafından
interesting info on that forum, so I guess we won't know before trying, cause he had success on 2008 iMac but not in 2010 iMac.
It would nice to know also random read/write parameters of PCIe mSata SSD. I mean if on my iMac 2006 is not much better than my actual HDD (which is 75/85 if I remember right) it's not worth it
tarafından
any news? did you try it?
tarafından
yup - it didnt work. I decided to do this instead: http://forums.macrumors.com/showthread.p...
tarafından
2 tane daha yorum göster
Yorum Ekle
My computer is a 2008 iMac running El Capitan.
I have installed an Iocrest JMB582 dual Sata card in the mini PCI-E connector (in place of the WiFi card) . At power up drive and directories and files can be seen briefly but drive then becomes disconnected and only seen after powering down and restarting. After powering off the drive by itself and then on again the blue LED, for the drive (on the JMB582) illuminates but nothing else happens. Does any one else have this issue or any advice on this issue?
Puan 0
Yorum Ekle
Yanıtını ekle
joleisa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 29
Her zaman: 5,745
