Code PO104 saying MAF sensor.Where is that sensor at exactly
2017 Ram 1500 Bighorn 5.7 check engine light, diagnostic code PO104 which is the Mass Air Flow sensor.Where is that sensor at exactly.
Bu iyi bir soru mu?
Puan
0
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 46
Tried Ram forums where owners may be more helpful? I use rockauto for parts lookup and don't see maf sensors listed. Map sensor yes. Maf sensor no. Virtually all mass air flow (maf) sensors reside in a round air intake housing between air filler and throttle body. The maf sensor itself is mounted into the housing with a multiple pin connector protruding from it. Be sure the intake air assembly connected to throttle body doesn't have an air leak between maf sensor and throttle body. All airflow must go thru the maf sensor to detect airflow volume for the EFI system.
F Dryer tarafından
