Ana içeriğe geç
Dell Inspiron 5559, 2015 yılında piyasaya sürülen 15 inçlik bir Dell dizüstü bilgisayardır. Onarım kılavuzlarını, sorun giderme yardımlarını ve diğer bilgileri bulun.
Can I replace intel board with amd board?
Dell 5559 i5 6-Gen board is dead.
Can I replace intel i5 6-Gen board with any amd board?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Highly unlikely if you want to fit it in your current laptop case, as it seems this model was equipped with Intel CPUs only; and even if you found a somewhat compatible replacement board, it would still require a lot of work.
Limited repairability/upgradeability is a well-known issue with portable devices, hopefully things are gonna change for the better in the near future; some progress was made, as a matter of fact you could have easily swapped your faulty motherboard with a new one if you had this laptop.
That said, if you don't mind getting your hands dirty, and refuse to take a risk and look for a used working Intel board, you could still recycle all the other components, there are many fascinating projects worth looking at: you could build an Arm based computer, or an AIO-like PC you could use as secondary screen, you could even try to build a tablet out of ur old machine; HDD and ODD can be repurposed too.
Hope this helps, feel free to let us how you fixed it
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part. Görseli
Ürün
2.5" Hard Drive Enclosure with USB 3.0 Cable
$14.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Masroor Amir sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 351
