Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
Fan connector Broken on logic board.
Hello everybody ( sorry for my english i'm french )
I just fix a macbook but i have a big problem the Connector for FAN is broken and when i try to soldering one point is not ok the three other is good ... so the fan work but allways at the same speed real problem because it's the highest speed and it's make SOME NOISE!
So i need to now if anybody know an alternative way to solder the fan on the logic board ( alternative point .... )
Thx
Bu iyi bir soru mu?
Puan 1
11 Yorum
Salut VicenzoReturn, pouvez-vous s'il vous plaît envoyer des photos de près de ce, que ce soit ici ou sur un site d'hébergement d'images? Quel genre d'optique que vous avez à souder sous? Y at-il de l'pastilles déchirés ou manquants? Dans quel état est l'ancien en-tête / socket? Si obtenir, croyez-vous qu'il serait possible de souder un raccord de ventilateur de nouvelles?
Hi VicenzoReturn, can you please post some close up pictures of this, either here or on an image hosting site? What kind of optics do you have to solder under? Are any of the solder pads torn or missing? What condition is the old header/socket in? If obtainable, do you believe it would be possible to solder a new fan socket in?
tarafından
yes i can do picture for you i will take that tomorrow morning for me in like 7 hours thx for your answer! i will give you a MP when it's done.
tarafından
ok Done i take the picture look and if never you have an alternative way to FIX it ! ( it's really appreciated =) In french good=)
http://www.hostingpics.net/viewer.php?id...
This is the Two pics!
tarafından
Cette image a ici une bonne lumière suffisante. http://www.hostingpics.net/viewer.php?id... Pourtant, il est au flou pour moi de voir de petits détails. L'autre image est trop sombre. Désolé d'être un PITA (douleur) Vous avez également jamais mentionné condition d'ancien connecteur. Il ressemble à un plot de soudure est déchiré ou manquant forment ce que je peux voir, pouvez-vous confirmer? S'il vous plaît excuser mon français. J'utilise Google Translator pour nous aider à mieux communiquer.----------------
This picture here has good enough light. http://www.hostingpics.net/viewer.php?id... Yet it is to blurry for me to see small detail. The other picture is too dark. Sorry to be a PITA (pain) You also never mentioned condition of old connector. It looks like a solder pad is torn or missing form what I can see, can you confirm? Please excuse my French. I am using Google Translator to help us communicate better.
tarafından
@ABCellars: I don't think there's still a connector on the board. I think he's trying to solder the cables directly on the pads. There are two other wires at the left of the pict ???
@VicenzoReturn: D'après votre photo le connecteur du ventilateur a été retiré de la carte mère et vous essayez de souder vos fils directement à l'emplacement oû était le connecteur ? Est-ce bien ça ? À quoi servent les fils situés à gauche de la photo ?
tarafından
6 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi , my picture help me lol ^^ i just solder on other point and everything work fine -) thx for your help .
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
nice picture you can see the trace for the missing pad. Glad you got it together.
tarafından
Yorum Ekle
Yanıtını ekle
VicenzoReturn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,363
