I cant get any spark , I replaced my cap n rotor notsure if its my co
No spark at all i replaced the cap n rotor im not sure if its the coil or the ignition module?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I know it's a different make/model than my own vehicle, but when I couldn't get any spark it was the icm for me. Located inside the distributor. I posted a pic of yours so you can see where it should be.
Bu yanıt yardımcı oldu mu?
I think there are several common-ish causes for this symptom. Without additional details of what all has been tried,. here are a few thoughts and some supporting links:
-bad key code
-Bad ignition coil(s)
-bad plug(s)
-damaged cam position sensor
-broken timing belt
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 42
1 Yorum
mattcannon48 what engine size does your Accord have?
oldturkey03 tarafından
