Ana içeriğe geç
Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Black screen but everything else works.
I bought a second hand macbook, still under warranty, apparently the last owner spilled some liquid on the equipment, causing a problem with the screen. Apple only accepts to do the repair if they change all the parts (Logic board, connector, screen), for me it's not feasible.
I can use the macbook with an external monitor without noticing problems, IO, camera, microphone, charging, keyboard, touch ID, everything works except the monitor.
Is it a good idea to buy the screen and repair only this part myself or is there a high chance the problem is in the logic board?
Image on monitor (looks like an x-ray)
Image on external vs internal screen.
Support Apple images:
My images:
No damage to monitor connectors.
A cable deformity.
Atualizar (05/16/23)
Updating with the solution to the problem. In my case the solution was to change the screen for an original apple one.
1- Carefully read the information on this page. https://support.apple.com/self-service-r...
2- Buy the screen and angle sensor from this site indicated by apple, yes you need to change both. https://selfservicerepair.com/home
3- It is mandatory to contact apple so that they can calibrate the colors of the screen and the angle sensor.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
After you reconnect everything, start it up and using a flashlight resting on the display at a sharp angle do you see a faint image of your desktop and icons?
If you do then the displays backlight circuit needs repairs, otherwise you will need a new display assembly.
If your system has a warranty, I would let them fix it.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
It has no details, but it was possible to notice a slight coloration of the screen. It looks like a high contrast of black and dark grey. I will add more photos to the initial post.
tarafından
@edsonluiz - Well this is a new one for me!
Do you understand how polarized light is twisted by the liquid crystal display panel? What we are seeing is the T-CON logic within the display logic is bending the light for intensity but for some reason the color pixels are not being activated.
The bottom line here is the display assembly is bad!
tarafından
I don't know how macbook panels work, unfortunately. Thank you very much for your help @danj, I think I will give a full screen replacement attempt, it seems to be the one with the greatest chance of success.
tarafından
Yorum Ekle
I have the same problem, but if I close the screen and back is works for seconds till it glitches back to this blurry black. Do you know what was the problem?
Puan 0
2 Yorum:
I am facing the same problem. Have you been able to get this fixed?
tarafından
Black Screen with Blurred Image means that the Backlight Controller IC is Defective. The other case of Patrick di Fusco is different (Closing and Opening) it seems that the LVD or Backlight Flex is Damaged,
tarafından
Yorum Ekle
Hello, I am facing something similar. In my case, the display goes to sleep randomly, and comes back on when I close & open the lid. Typically, this problem starts after 30 mins of usage, and then it goes on for a while
Did you manage to get this fixed? If yes, what did you eventually do?
Puan 0
Yorum Ekle
Yanıtını ekle
Edson Luiz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 105
Her zaman: 2,347
