How do I fix a lamp with a short? The bulb flickers on and off.
my floorlamp bulb flickers on and off and only holds a light if balanced in a specific position. i think there is a short in the connection. how to fix?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Just try replacing the lightbulb 💡
Bu yanıt yardımcı oldu mu?
I tested the bulb, of course, on another fixture. It's fine. And the lamp is plugged in.
Then I guess you should consider replacing the lightbulb socket, but can’t say more specifically until we see an exact unit
@mcb48 if changing the bulb does not help you may need to check the wiring in the light fixture itself. Remove the bulb (unplug your lamp) and take a picture of where the bulb normally sits. And one of the bulb itself. that way we can see what fixture your lamp has and hopefully can be more specific with our answer.
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 108
