Ana içeriğe geç
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
Screen is Not working after a few weeks after exchange
Heyho.
I exchanged the screen and after 2-3 weeks it began sporadically Not to work (Black screen). With a bit more pressure on it, it worked again. Meanwhile screen is dead.
I reoopened it, but couldnt find any mistakes or unfixed plugs.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi
The cables for the display are pretty tricky to get to on this model so it can be quite hard to see if there is any debris in the connector so what I would recommend is removing the battery (just so it’s no longer adhered to the chassis but still soldered to the logicboard,removing the battery helps get more room to access the back of the logic board)and clean the connectors(both screen and board) with isopropyl alcohol
If that doesn’t work try the old screen and see if that shows similar results
If it shows similar results the connector on the board may be damaged and will need replacing by someone who has good micro soldering skills
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Hi, THX for ur answer. I did remove (but leave it connected) the battery while exchanging the display.
I will clean the plugs like u described and give response. ;)
Many THX.
tarafından
@nikolasb
Good luck:-)
tarafından
It wasn't succesful and i haven't the old Display.
So only Thing i could try is to buy a New one?
I'm afraid that there is something Else but the Display. What could be the reason for this error behaviour i described?
Thx
tarafından
@nikolasb
Did u try cleaning the connectors?
tarafından
Yorum Ekle
Yanıtını ekle
Nikolas Blenk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 153
