Ana içeriğe geç
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
20 Soru Tümünü görüntüle
Won’t charge or turn on anymore
It won’t charge or turn on. I’ve had this issue looked at before but now again it won’t charge up nor turn on. I’ve changed out the USB-C power adapter to an 87 watt as was suggested by the last repair yet again it’s not charging in either charge port I plug it into. Thoughts ? Thanks so much.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
If your Mac laptop with USB-C can't charge
If your USB-C power adapter cannot charge your MacBook, MacBook Air, or MacBook Pro, try first unplugging the power adapter from the power port, wait a few seconds, and then
Then connect it again. If this does not solve the problem, check the following things
  • Check the power source
  • Check cables
  • Check for updates
In some cases, software or firmware updates may be available for your computer that improve connectivity to your power adapter
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
If either of the ports don't work. It must be the battery, iFixit probably has a guide and kit to fix it, hope this helps!
Or, try booting your mac into recovery mode, and reset or something?
Puan 0
Yorum Ekle
This may need the logic board repaired which is quite advanced for many.
If both ports on each side don’t charge your battery I would connect a USB-C power meter inline with the charger so you can monitor the charger and how the handshake between responds. While it’s possible your battery needs replacing unless you are a serious road warrior yours should still be good.
Here’s one example: Power Meter
Puan 0
Yorum Ekle
Yanıtını ekle
Caleb Schafrath sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 432
