Washer can't go into rinse and spin
Washer can't go into rinse and spin, it tries but can't ingage
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @fishlake
I assuming that you mean that the wash tub tries to spin but can't and not that the washer's cycle timer can't step on to the rinse cycle from the wash cycle, as your question is a little ambiguous, is this correct?
If the cycle timer does step through the cycles OK but the machine can't spin during the rinse or spin cycle it may be a problem with the drive coupling
The supplier link above are only to show the part, they also have a video that shows how to replace the part and they have the manufacturer's part number listed as well.
If this is the problem, search online using the manufacturer's part number only to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Coupler was replaced with transmission. .
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 11
Her zaman: 49
5 Yorum
Hi @fishlake,
What is the model number of the washer?
jayeff tarafından
20882990 is the model
Marvin tarafından
We've replaced the motor, clutch, transmission, and pump. It isn't the safety switch.
Marvin tarafından
Also replaced timer the old and new still cause the same issue.
Marvin tarafından
It's a Kenmore
Marvin tarafından
