USB port on phone loose
The USB port on my phone, Galaxy A01, will not hold the connector on the cable tightly. This makes keeping a connection difficult. Can the port be repaired or replaced?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@hoser010 the USB port is actually on it's own Charging Connector Flex Cable Samsung part number GH81-18208A. Since we do not have a guide for this (hopefully you'll make one https://www.ifixit.com/Guide/new ), check something like this video to replace that flex.
This is the part you would need to replace
Bu yanıt yardımcı oldu mu?
Thank you for the quick reply. I don't understand what a "connector flex cable" is. I watched the video you linked, very interesting. It showed the USB connector in the phone, which is where my problem seems to be. I have plugged several different cables into the port with the same loose result.
@hoser010 sorry should have left a picture. Anyhow,it is added. The part that is marked as Sub PCB is what you would need to replace.
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 226
