Ana içeriğe geç
The Dirt Devil Gator is a cordless hand vacuum designed by the Dirt Devil. This lightweight, creatively designed vacuum will provide a powerful suction to clean those hard to reach areas! Model number: BD10100
My dirt devil will not start or charge
I get a blue light otherwise it’s dead. It won’t charge or start. What’s my problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
I have an older model dirt devil dust buster. Have not used in a long time. I only gst the red light saying its charging. Been doing this all day. Do I need a new one?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@sparks203, First make sure the charger is working (use a DMM, digital multimeter) and outputting the correct voltage.
The first suspect in cases like this, is always the battery. A bad p / dead battery is the primary cause of no charge and no power. Try opening the Dirt Devil up, to gain access to the battery, and then test the voltage of the battery.
You didn’t specify your model, but here is a link to p25 of the operating manual of a Dirt Devil. It shows which screws to remove to get access to the battery.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I have used it once. Plugged it in a good outlet to charge. Checked everything Worked for about 10 minutes. then nothing.
tarafından
carol larocque, If you bought it new, and it won’t take a charge, I’d say take it back under warranty, because you might not want to void the warranty. If you bought it a “long” time ago, and it’s been sitting on the shelf, the battery could have gone dead.
tarafından
Yorum Ekle
Plugged it in once after usage. Worked for about 10 -15 minutes. All charged and cleaned. New. Second time using.
Puan 0
2 Yorum:
Had my old Dirt Devil for 10 yrs or more. No Problem. Gave it to my daughter. Still works. Used me new one once. Plugged it in, checked everthing. Still not workinng.
tarafından
Mine only shows the red light. Been charging for numerous hours. Have not used in a long time. Dirt devil older dust buster
tarafından
Yorum Ekle
Yanıtını ekle
Susan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 27
Son 30 gün: 129
Her zaman: 4,019
