Ana içeriğe geç
İlk olarak 2012 yılında piyasaya sürülen, MacBook ürünleri için 2. nesil manyetik AC güç adaptörü. Önceki nesil sistemlerle uyumlu değildir. 45W, 60W ve 85W sürümlerinde mevcuttur.
Check if work with multimeter
Hi everyone,
I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.
How can I check this charger with multimeter to know if its work or not?
Would appreciate your help
Update (12/09/2022)
@geirandersen I set a multimeter at the setting (see pic) and the it showed 3.1
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@roderos I’ve attached a pinout image for the MagSafe 2 charger.
Test black probe on Ground and red probe on Power. Both Power pins should have very similar output. If there’s a large difference or the voltage if the voltage isn’t ~20V, you have a bad charger. By large difference I mean anything more than a few millivolts.
Resim
Bu yanıt yardımcı oldu mu?
Puan 6
16 Yorum:
So the output from both Power pins must be around 20V?
I have 85W charger.
tarafından Paylaş
@roderos Yes. You can use any of the Ground pins, but both Power pins should have ~20V. Output voltage doesn’t change with Wattage rating. It’s the amperage that it can possibly draw that is higher on the higher rated chargers.
tarafından Paylaş
@geirandersen just have a chance to test it out now. sorry for silly question, do I need to have charger plugged into the wall to test it?
tarafından Paylaş
@roderos Yes, the charger must be plugged in to the power, otherwise it has no output ;)
tarafından Paylaş
@geirandersen thanks :) I tested x3 chargers both pins an all of them show 3.08-3.1 at DC Voltage 20. Does that mean that they work at full power?
tarafından Paylaş
11 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Yurii Chaikovskyi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 147
Her zaman: 13,511
