Ana içeriğe geç
My top ribbon doesnt work
When I was changing the battery I had to unplug the top ribbon that holds the aux, cameras and power button and now ive plugged it back in the whole top ribbon doesnt work what could I have done or fix it?
To add to that now it doesnt turn on at all after Ive closed it to make sure its properly plugged in
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
TheBlooner AceTin, Unfortunately, even though it might be a pain, you’ll have to open it back up again! Once opened, unplug the battery and then the other connections you had off before. Inspect the flex cables and connectors closely (a magnifying glass at least, if you don’t have a microscope) and then clean both sides (board and cable) side of the connectors with >99% isopropyl alcohol. Normal rubbing alcohol and the likes will not do, as they mostly contain to many additives to the alcohol.
Once you’ve inspected and cleaned everything very thoroughly, connect everything back (battery last) and check functionality before closing it up again! That last part is learned through experience (I had to open the first few devices I did back up again, because I hadn’t checked and verified functionality).
If it still a problem even though everything looks OK, let us know and we’ll have to dig a bit further.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Is there something else I could use if I dont have isopropyl alcohol?
tarafından
TheBlooner AceTin, Unfortunately there’s not much. The only thing is to get some form of HIGH percentage alcohol. Most rubbing alcohol is 70% at best, which isn’t enough. It needs to be at least 90%, and as few additives as possible
tarafından
@TheBlooner AceTin Forget the alcohol. I’ve repaired iPads and tablets, mobile phones for years and not used alcohol on connectors once. Remove and reseat the top cable making sure it’s inserted correctly and all the way in then try it with the device still open. If it still doesn’t work check the cable and connector for damage.
tarafından
Yorum Ekle
Yanıtını ekle
TheBlooner AceTin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 306
