Why is my 3ds not turning on?
it doesnt have water damage so i dont know why it wont turn on. it seems to be stuck in sleep mode
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Could you elaborate a bit more? Does it show a red light, or a blue light, does it have custom firmware ect.
Bu yanıt yardımcı oldu mu?
It would be good if you could post some more information about what is going on with your DS. For example when you try to turn it on do any of the LEDs such as the power light turn on? Does the charging LED turn on when it's plugged in? Are you running some custom software on your DS? Do the screens remain completely black or do they
If you plug your DS on and none of the LED lights turn on that could mean that your charger is bad and you need to try charging it with a different charger.
If your charger isn't the issue and the lights still don't turn on with a good charger plugged in that could mean that you need a new battery.
hey i was wondering if u could help with my problem? my problem is that my 3ds xl wont turn on, the light appears as ifit was, but the screen just stays black, the only difference is that the blue light just shuts of after a few seconds, is there any way to fix it?
someone hit it on the side and it worked, try that maybe?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 150
what makes you think it's in sleep mode?
just some mango tarafından
