Ana içeriğe geç
Flipper Zero, sensörler, alıcılar ve diğer elektronik bileşenler gibi çeşitli elektronik cihazlar ve sistemler üzerinde hackleme, hata ayıklama ve denemeler yapmak için tasarlanmış çok yönlü bir çok amaçlı cihazdır.
GPIO 17 for iButton Came off
Help, how do I repair GPIO 17 pins at the back which is used for the iButton feature? Tried opening the device and the clips were bit to tight when prying open and when I lifted the cover off it took two pins of the GPIO 17 off. Any suggestions on how to fix? Doesn't look like a solder tho..
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Have you resolved your issue? im having the same problem help please
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Unfortunately, the Flipper team does not currently sell replacement parts. However, you can contact them to be added to their waitlist.
Another option is to purchase a broken Flipper Zero that still has a functioning GPIO module and use it in your device.
You can also bypass the iButton pin by just connect a wire from GPIO pin 17.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
NOTE: The Flipper team has begun selling parts to people who’s on the whitelist, don’t know how long it will take for them to be available for everyone but for now they only sell 2 parts (Top Case and Screen). You need a code to order the parts, you can order them on https://shop.flipperzero.one/collections...
tarafından
Yorum Ekle
Yanıtını ekle
Raymond sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 2,360
