suddenly it stopped power
I came one morning found that the computer suddenly stopped powering .. someone tried to fix the motherboard but it didn't work ... any help?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
power supply could be the issue does it test if it does if it does then that means the charge port isn't faulty next test the battery be careful and see if you can get the battery swapped if that doesn't work try the power supply then finally id say check the power button the things I’d say it was that it was the power button and or power supply
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 279
haidy Mikhail "someone tried to fix the motherboard but it didn't work" what did they try? What has been checked? We got to start somewhere to help you but need to know what you have already checked.
oldturkey03 tarafından
