Ana içeriğe geç
Intel'in oyun odaklı NUC serisinin Skull Canyon nesli.
Question identifiying SMD Component - Capacitor?
Hello everyone, I have a question that I posted on Reddit and got a few contradicting answers. I purchased this Intel NUC6i7KYK as "Parts" on eBay because it was power cycling. I originally thought it just needed some cleaning and new Thermal Paste, but that is not the case. I was looking at the bottom of the board, and found what I believe to be a blown capacitor. I attached a stock picture, and circled the component in blue. I know it is impossible to identify the exact specs of this part, but at least knowing what type of part it is will point me in a direction to troubleshoot. Since the board is dead, I really have nothing to lose by trying to fix it and learn from it. According to Reddit, it is either a fuse, capacitor or resistor. One suggestion would be to put a 0ohm resistor in and try it, but I don't want to do that if it is actually a capacitor. Thank you in advance!
Resim
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Looks like a resistor, the caps are a browny colour. I’d try and find a resistor the same dimensions and try it. Remove it from the board first and see if there’s any measurement across it. I’d also check for a bad mosfet.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Perfect, thank you very much for the quick reply!
tarafından
I think it is a ferrite bead, used to filter out noise from the power line. See for more information:
https://www.analog.com/en/resources/anal...
tarafından
Yorum Ekle
Yanıtını ekle
Likwid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 39
Her zaman: 797
