Spacebar fell off, then 2h later spilled icetea on MacBook
I bought my macbook pro 14 2021 a few weeks ago.
Yesterday I noticed my spacebar feeling mushy, I pressed it a bit harder a few times and it worked again.
Then later it became lose, so I thought I just have to press it back in, went in fine but made cracking noises since then. So I just kept working with it.
Then the left side of the keycap just fell off. I pushed it back inside, not thinking much of it.
A bit later that day I had an accident then, I put a little icetea bottle infront of the mac and apparently the bottle was uneven at the bottom, as it just fell over (got it from pizza delivery), so it fell right onto my macbook.
Most of the liquid ran down to the table as I always keep the macbook on a laptop stand at around 20° angle.
I quickly wiped it with tissues, then turned it around and started shaking it to force any liquid out the air exaust (may not be so smart, I know, as the liquid may have flown up towards the display now)
I opened it up, after no liquid was coming out anymore. There was a bit of fluid on the fan that is below the jkl buttons (which were sticky as well until I cleaned them)
I slowly cleaned everything with a microfibre cloth that was slightly soaked in isopropanol until I didn't see anything left.
Laptop seems to work, I started some games from steam to make the chassis heat up a bit and force it to dry any residue, but then I noticed 2 pieces of transparent plastic below the spacebar, lifted it up slightly and apparently the pins that hold the lower metal wire on the left side fell off which explains why the button felt so weird, as probably one of them was stuck in the membrane.
I carefully held my vacuum cleaner next to it on lowest setting to remove those bits, but the spacebar keeps "unhinging" since those 2 pieces are missing.
I already talked to Amazon and Apple, both would "try to repair it", but I am scared that they might just break it or soak it with alcohol so that it breaks later.
Would you guys recommend me to send it back to repairs or open it up and clean it further?
It seems to run fine but I don't want it to develop any corrosion.
Also I saw that some of the components are under some kind of metal cooling-sheet that is soldered onto the logic board now, so no idea if I could see any residue there.
Update (12/23/2022)
Note: I type very gently, not one of those 'push the button through to the table' type of guys. Maybe the way I press the spacebar puts much stress on that corner, as I am used to press right on the left edge of the spacebar, because I switch between Command and Spacebar a lot when programming
Bu iyi bir soru mu?
