Where can I find the PCV valve in my beetle?
I got steam coming out the oil cap and I have rough RPM
Update (12/26/2022)
VW Beetle 2.0L 1999
Bu iyi bir soru mu?
VW Beetle 2.0L 1999
Bu iyi bir soru mu?
Although a PCV valve is an inexpensive item to replace and would be worth trying as a first pass, the symptoms you describe can also be attributed to a much more serious issue, that of a blown head gasket. If the PCV valve doesn't fix the problem, you should probably check the compression and run a block check test as your next steps.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 471
