Mac Mini (late 2014) heatsink making noise in vertical position
Hi there,
Hope you are fine.
Please, check this video: https://www.youtube.com/shorts/VAdzQVJH6...
I want to setup my Mac Mini in vertical position. There are three options: (1) wires at the left and Apple logo turned 90 degrees to the left, (2) wires at the top and logo in standard position and (3) wires at the right and logo 90 degrees to the right.
For positions (2) and (3) everything works fine. However, when using position (1) I started to hear a metallic weird noise. My first thought was it is the fan but to my surprise it was not: removed the fan and still the noise, I figured out it is the heatsink: if I remove it, there is no noise.
The heatsink itself looks to me as a really solid and compact piece, I don't see where the noise could be coming from. I cleaned and removed everything that can be cleaned and removed, but still getting the noise.
Any thoughts or help? I can quickly share a video if needed.
Thank you very much for your help. I am going nuts.
Bu iyi bir soru mu?
6 Yorum
Hi
Would you say that the noise sounds like a vibration?
If so you could use some rubber strips to stabilise it and minimise the vibration
A bit like a shock absorber:-)
HelloMacOS tarafından
@hellomacos Hi there, thanks for the response!
No, it is not a vibration, i would say is more like two pieces of metal fighting. Same sound like when you are frying an egg.
I am working directly on the board, so no that much space to add any rubber strips :D
Thanks for the help!
Juan tarafından
@juan2022
I don’t recommend doing this for long but if you remove the heat sink does the sound go away
I’m wondering this because you described it as like when you are frying a egg
There is some fluid is heatsink’s and I suspect that the heatsink may be on its way out if that’s the case:-)
Yeap, when the heatsink is removed, the sound goes away. Do you know any place I can get a new heatsink? Can't find a model for Mac Mini late 2014
Thank you!
Juan tarafından
@juan2022
Just done some looking around and I found this one
https://www.ebay.co.uk/itm/154709331824?...
Hopefully it’s in your region:-)
1 tane daha yorum göster
