Ana içeriğe geç
The Canon PowerShot S90 is a high-end 10.0-megapixel compact digital camera originally announced in 2009.
7 Soru Tümünü görüntüle
Camera len don't come out
I press on the lens while it was working then the lens doesn't show up
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
LAETH ATHER_81 you can try and fix it first by moving the lens from side to side. It is possible that there is grime/grit/dust/sand in between the lens mechanism. Look at the lens and check it against the lens ring. See if is centered or if it is off center. If it is off-center, a little push on the side that is higher may make a difference. For some really useful tips on this, check on here. I've used a shopvac on a lens before, to assist it with extending. If nothing gets this resolved, you may have to consider replacing the lens.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Try to take a flathead screwdriver and pry the lens up.
Puan 0
Yorum Ekle
Yanıtını ekle
LAETH ATHER_81 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 249
