jpearson85, Yes, it’s possible to fix (assuming it’s just the connector(s) that are gone), but it will require board level repair.
It means that you will have to use micro soldering skill and equipment in order to replace the connectors, if they are burnt. You will also have to assess further damage, as you could have a cascade effect on water damage.
The first step is to disassemble everything and using some >99% IPA (isopropyl alcohol) and a toothbrush or even better an <Ed’s safe brush, then clean off everything (gently, but firmly) that’s showing damage. Some of the components are tiny, and can be broken / ripped off if using too much force.
Once everything has been thoroughly cleaned, and you have inspected everything with a magnifying glass; If it looks OK, then put it back together to test and then do a new assessment.
The work in replacing the connectors requires the use of some “pro” level tools, hot air rework station, microscope, +++ It’s not advisable to do your first board level repair on a device you’re using. Recommended to practice a LOT first, in order to gain skill. Many people use iCloud locked boards to practice on, as they serve no other purpose, and can be found pretty cheap around the net.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
3
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
