Ana içeriğe geç
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
MacBook Pro 2011 Won't boot from a internal SSD
Hi
My system will not boot if I put a Bootable SSD internal, the same SSD will boot from a USB enclosure, I have change the HHD Cable 2011 with one from Amazon and still no luck.
The system will boot fine from a 1.5t HHD internal or USB I can even boot from a SD card.
if I hold down the option key with the SSD internally the system sees it and the recovery drive but when I select it I just get the flashing folder..
so I have read that I should order the 2012 cable as it is much better then the 2011 cable.
any help wold be great
Terry
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would still replace the HD cable as SSDs run harder so a weak cable often shows up under it Vs a HDD.
Did you select it as your boot drive?
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Yes I replaced the cable from Amazon and still no luck, but the same SSD will boot fine from a USB enclosure
tarafından
@Terry Genereaux - Did you check the startup drive within prefs? Also did you install the same OS version your HDD has?
tarafından
Yorum Ekle
Yanıtını ekle
Terry Genereaux sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 131
