Drive problems works externally not internally
It runs a standard 1.5tb hd just fine and I can boot from my ssd in an external case but when I put it into The MacBook Pro it will not boot strange
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
I would still replace the HD cable as SSDs run harder so a weak cable often shows up under it Vs a HDD.
Did you select it as your boot drive?
Bu yanıt yardımcı oldu mu?
Yes I replaced the cable from Amazon and still no luck, but the same SSD will boot fine from a USB enclosure
@Terry Genereaux - Did you check the startup drive within prefs? Also did you install the same OS version your HDD has?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 71
