Ana içeriğe geç
Repair and disassembly guides for the Nintendo Switch OLED Model, announced and released in 2021.
Switch oled not turning on after housing replacement
Hello! Would appreciate so much wisdom in this issue I did to myself haha 😅
I was replacing the backplate and bottom bar yesterday with extremerate shells and although I did everything carefully, may not had been careful enough as once almost closed, I tried to turn it on and didn't respond 😅 checked if everything was connected, the battery cable, the 5 ribbon cables and all as doesn't seems I forgot something to connect, tried connecting it to the dock to see if it was a display issue but it just blinks once the dock and turns off, tried turning on that way and nothing, left it charging overnight and pushing thr power button for 30 seconds and 30 seconds other combinations and nothing
What I did notice tho is that when I plug the battery its silent but once I hit the power button it starts to do a barely audible buzzing sound in the charging area which said sound isn't audible once everything closed
Tho one cable I admit might had bent too much is the fan one as some of you may know is kinda of a difficult place to put if not having the right tools ^^;
Any idea of what could be and things I could try to make it work again?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I've got the same issue...
Did you resolve this and how please?
Many thanks 👍🏻
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Anthony Lopez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 89
