How do I replace just the front glass?
Out of all the videos I've seen, most just get a full lcd replacement. I don't want to replace that, I just want to replace the screen glass.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi Lily,
The problem here is that the LCD and front glass are bonded together with a glue called OCA, or Optically Clear Adhesive. It generally requires specialized tools, equipment and experience to separate them successfully, and then rebond the new glass to the old LCD. In almost all cases it's not worth the time and effort it takes to do that; in order to make sure you don't get bubbles in the glue you need to cure it in a vacuum chamber, which most of us don't have at home.
Since the replacement display sells for under $25 USD on AliExpress, it's really not worth your time to mess with separating the glass, cleaning the LCD, ordering the correct OCA and then trying to get it reglued without bubbles. I strongly recommend you just bite the bullet and replace the whole thing.
Bu yanıt yardımcı oldu mu?
Mi pantalla está roto
For those of us who don't speak Spanish, Google says this means:
My screen is broken
Hi Yanick,
Assuming you're coming here for help in repairing your screen, even though iFixit doesn't have any information on your phone, that doesn't mean we can't be of assistance.
This same repair has been addressed on here previously; see the following post for information on replacement parts and instructions.
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 1,112
