Ana içeriğe geç
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Kernel take about 90% from CPU
Good Day,
Im have problems, with Imac EMC2544, that Fan speed and very slow to do anything,
when I checked the Active Montier I saw the Kernel take about 90% from CPU , so I did clean install , it takes more than 14 hour to finished and the mouse moves so slow and it sometimes stop moving.
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This behavior is pretty indicative of either an issue with overheating, or one of the sensors. Kernel task, if that’s what you’re referencing is a process responsible for many things, and one is sucking up CPU cycles from other processes that the device thinks may cause issues with heat, or stress the system.
This is also normal behavior if the Mac thinks one of its sensors is missing, or is giving bad readings. Try running Apple Diagnostics by pressing and holding the D key immediately after you hit the power button to turn your machine on.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks ,
I have run diagnostics , it shows ( Error:080000000000003, Cannot Load EFI/Drives/TestSupport
Status: 0x00000003
tarafından
@flannelist - Looks like Apple has struck again killing diags on older systems!
tarafından
Yorum Ekle
Yanıtını ekle
Moe Shtewi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 134
