Ana içeriğe geç
50" Plasma TV by Sanyo released in 2007.
79 Soru Tümünü görüntüle
Two Vertical Lines and Dark blob on screen of 40” Sanyo Old Model HDTV
My Sanyo 40” Flat screen TV (Old Model) has two vertical lines and a red blob. A friend gave it to me saying he never used it and didn’t know if it worked. When I first turned it on, there was one line and no blob, an hour later there is two lines and a dark Blob on the screen.. Is there anyway to fix this?
How it was at first:
How it is now:
Bu iyi bir soru mu?
Puan 1
6 Comments
@spencer22 we do need to know the exact model for your TV.
tarafından
@oldturkey03 how do I figure that out?
tarafından
@spencerc22 there should be some sort of label on the back of the TV.
tarafından
@oldturkey03 I think it’s DP37647
tarafından
@spencerc22 that would make it a 37" diagonal screen. Sounds right? Also, that would make it a LCD TV not a Plasma. Do those lines and the blob appear immediately or does it take a bit of time to show up?
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@spencerc22 okay so your TV is a LED backlight TV. The "blob" looks like a backlight that is going to go dim. In order to fix that, I would suggest to replace the LED backlight strips. Not a bad job on this panel since it is not to big. The two lines are actually more of an issue. Those look like Tab errors. Your LCD panel has driver boards that are connected to the panel via some very thin ribbon cables. Those a bonded to the panel (essentially glued). The bond is coming loose or may be corroded. Not sure how difficult it is on your TV to get to those. Here are some examples of what you are looking for
Now apply some pressure on the Tab that is located where your lines are. If those lines disappear or change, you know that this is the problem.
There is no permanent fix for it for the DIY'er. Sometimes applying a strip of thermal mat and either wedging it between the Tab and the TV bezel will apply enough pressure to continue to make contact. Sometimes you can use a piece of thermal mat and attach it with some adhesive tape Yes, duct tape would work as long as you don't tape it right on the ribbon cable. Always use something between the tape and Tab.
To repair the backlight, you will have to tear the panel down. Check something like this video Different model but in principle they all look very similar. Just take your time and if you get stuck somewhere, take some pictures and post those with your QUESTION so we can try to continue to help you along.
That is really all you can do at this time. It is not a bad fix and will keep your TV going for another couple of years.
REPAIR IS WAR ON ENTROPY!
Bu yanıt yardımcı oldu mu?
Puan 0
5 Comments:
Is there any fix for the blob other than buying a replacement?
tarafından
@spencerc22 that is your backlight array. Probably a bad LED so you would have to replace the strip. Sometimes you can replace the single LED by soldering it to the strip, but you will then have a lighter area on your screen.
tarafından
Update: The blob has gotten DRASTICALLY darker and in the same spot as the blob, the picture bled through.. like a stillframe.
tarafından
@spencerc22 possibly your display going on the fritz or the LED pooping out. Can it be seen on an additional image
tarafından
I Can tomorrow after work :-)
tarafından
Yorum Ekle
Yanıtını ekle
Caiden Spencer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 79
