Ana içeriğe geç
Intellivision, Mattel tarafından 1979 yılında piyasaya sürülen bir oyun konsoludur.
Help with my Intellivision
I just recently got a Intellivision that was assumed working when I got it for $15 and when I got home to test it, it didn't work. It appears to be sending a signal to the TV, but it wasn't sending a picture. It is supposed to be connected to a VCR but it uses coax in an RCA connector plug.
UPDATE
Replacedthe capacitors and guess what. Nothing. Should I redo the joints? Used the Exact same capacitors.
Bu iyi bir soru mu?
Puan 1
6 Yorum
Did I spell Intellivision correctly?
tarafından
hello, you absolutely spelled it right ;) anyhow, have you tried to connect it through a VCR?
tarafından
Yes, I did connect it to a VCR (who has those anymore? I guess I do.) I got the results that are noted above.
tarafından
I am sure you watched the polarity of the caps when you soldered them in? Any thing else on the PSU that looks out of whack? you said before that the voltage was not matching. what do you get now?
tarafından
The polarity is correct I didn't replace the voltage regulator though, should I replace that?
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello, check this from the service manual:
1. Connect the Master Component to TV, plug in power cord, set the Antenna Switch Box to TV and determine that the set works correctly on broadcast stations.
So, make sure that your switch box is set properly.
UPDATE
Here is a link to an online service manual that can further help you narrow things down.
Bu yanıt yardımcı oldu mu?
Puan 3
14 Yorum:
Sorry, I didn't know what a switch box was. Do you know where I can get one?
tarafından
This will explain some more http://www.atariage.com/howto/connect.ht... and your best bet would be to try Google to get a switch box. They are still around but hard to find. Not knowing where you are, you might want to try Radio shack as well.
tarafından
Thanks, I found it on AtariAge, and the adaptor is at RadioShack for $4.19. I will buy it tommorow and see how it works and tell you guys. Thanks oldturkey03!
tarafından
Sounds great, good luck to you. Hope it works out and let us know....
tarafından
Unfortunately, it didn't work out. But, I've found the culprit! It's the power supply. It was in the Intellivsion Service Manual. But, does anyone know where I can get one of these. I don't want to have to rebuild it(even though I know soldering pretty well).
tarafından
9 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
thelectronicnub sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 30
Her zaman: 6,362
