Ana içeriğe geç
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
369 Soru Tümünü görüntüle
3DS XL no power unless I hold the battery a certain way
New post since I didn’t solve the problem
Took apart my DS to switch something inside, now it won’t turn on and is 100% dead unless I hold the battery a certain way and push it in the battery piston thingys.
When I place it in the housing it shuts down. Why is this happening? I haven’t used this 3DS for more than a year-2 Max so i don’t think the battery is the problem.
Is the battery not making contact with the pistons?
I have put up a video which shows the issue. Have been trying to fix this for days and no solutions.
Please help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello World this "hold the battery a certain way and push it in the battery piston thingys" sounds like your battery contacts are not touching the battery properly.
Make sure that the housing is not pushing against the contacts and that they are properly seated.
You can try and gently pull those contacts and see if they are bend or you could try to solder on to those. Of course, you can also replace the battery connector which will require desoldering the old connector, finding a replacement and then soldering it onto the board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Hello World sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 178
