Ana içeriğe geç
Repair guides and disassembly information for the Samsung Galaxy A8. Android smartphone. Released in July of 2015.
How to repair rusty charging port connector
i have water damaged charging port cable connector.(the connector that connects the charging port to motherboard) how to remove rust from it.also it is in half working condition like charging is there but no back button lighting.and the fingerprint is also the same it was working but stopped because of rust.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@parthsarthi if it is rusty at minimum that would mean the nickel will be off and it will no longer make good contact etc. Combining this with the other issues you are having I suggest that you replace the daughter board (which has the connector on it) with something like this. You did not tell us what you have done about the rest of the water damage. It is important that you deal with all of that as well.
This Video will help you with the repair.
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
@oldturkey03
only the charging port is rusty because the water only entered through sim socket so rest of all is in good and working condition.but the battery is not holding charge so i was asking that i should replace the board or replace battery . as the charging port connector where it connect to motherboard is also rusty but working that why i was asking to deal with motherboard rust.
tarafından
@parthsarthi based on this "charging port is rusty and "the battery is not holding charge" you want to do both. Replace the board and battery.
tarafından
@oldturkey03
can i use isopropel alcohol to give it clean and try?
tarafından
@parthsarthi of course you can. Remember so, that with all the issues it'll not just be that the port corroded. There will be corrosion on the board where the connector sits and possibly on/under the components of the board.
Trying to clean it is not going to hurt it:-)
tarafından
@oldturkey03 thanks i will make sure everything is done properly.thanks for your help.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
parth sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 472
