Ana içeriğe geç
Xiaomi Mi 11 Lite, Xiaomi tarafından Mart 2021'de piyasaya sürülen orta segment bir akıllı telefondur. 6,55 inç AMOLED ekrana, 64 MP ana kameraya, yan tarafa monte edilmiş parmak izi sensörüne ve 4250 mAh bataryaya sahiptir; gücünü Snapdragon 732G işlemcisinden alır.
No finger print settings and wont functioning?
my finger print wont functioning and disappear on my settings. i using xiaomi 11 lite
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
Did you try factory reseting the phone ?
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I've had the same problem for a year
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I had to send the phone back to Xiaomi, bad figerprint scanner.
It's a common issue.
tarafından
Yorum Ekle
The phone switch does not work
Puan 1
Yorum Ekle
I had the same problem with fingerprint sensor not working and then after some months the power on/off switch has been gone to the other world.
I have bought a new one and changed it following iFixit guides. Now all it is working.
Puan 1
Yorum Ekle
How to assemble fingerprint sensor?
Puan 0
1 Yorum:
after removing the bcakcover you need to remove the plastic antenna group and then you have to carefoully peel the battery without damagin it. Then you are able to remove the old fingerprint button/flat after removing the metal piece maintaining the button in place. Take care to deeply clean the housing where the button works and to properly put the new one in the hole.
tarafından
Yorum Ekle
I got a fingerprint sensor from aliexpress and the problem was fixed. It needs care during assembly, there is a metal piece that holds the button which compresses the tape, it's probably the reason of the fingerprint malfunction
Puan 0
Yorum Ekle
Yanıtını ekle
cid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 1,010
