Ana içeriğe geç
The third generation Audi A6 model was introduced by the German manufacturer in 2005. Based on the Volkswagen Group C6 platform, the new A6 featured the same Audi-styled single-frame grille and a revised suspension.
Steering wheel and cruise control retrofit help
Hello, has anyone done msfw and cruise control retrofit? I need some help
Im just stuck at this retrofit and cant make it work
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
hello.just concluded on my avant 3000tdi quattro from 2008. if you explain the problem better, I should be able to help you. did you install the cruise lever? did you bring the signal wire from the connector behind the levers to the white connector under the water tank of the wipers? did you do the coding?
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
So I managed to recognize CC lever in VCDS, its working just fine and I coded it but I didnt know about the wiring part
Can you explain from where to take the wire?
About MSFW it just wont work, coding is accepted and steering wheel light up but not responding to commands
tarafından
Forgot to mention, cruise control works in vcds but not working while driving
tarafından
Yorum Ekle
Yanıtını ekle
Uros Ivanovic sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 534
