Ana içeriğe geç
2015'in başlarında piyasaya sürülen Canon PowerShot SX530 HS, Wi-Fi özellikli bir süper zoom fotoğraf makinesidir. Bu kamera yaklaşık yarım kilogram ağırlığındadır. pc2200 model numarası ile tanımlanır.
Camera's shutter does not close when taking a picture
Camera is actually Canon Powershot SX430 IS but could not find it listed in the site.
Usually whenever I take a picture, the camera would produce a snap sound which I thought would be the camera's shutter. However, recently the camera would not close the shutter when taking pictures as there is no 'snap' sound produce after pressing the shutter button, causing the pictures to appear overexposed on the camera. Everything on the exterior of the camera seems fine. Could the shutter be jammed?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
Have you found any fix for the issue?
tarafından
My camera's model no. is Canon SX430IS
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hi @zerot,
Don't know about the shutter's mechanical operation, have you tried all operating "modes" to see if the problem occurred in each mode in case it is a software problem only in one mode.
Try resetting the camera and check if that resolves the problem see p.109 the user manual.
The shutter "sound" volume is adjustable in Settings, check that it hasn't been turned off - see p.103 in the manual
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hi there,
I have tried operating in all the different modes and resetting to default settings but still the shutter would not close with the pictures appearing bright and overexposed. And no, I am not referring to the sounds from the camera's speaker as I have muted the sounds ever since I first used it.
tarafından
I have the same problem. Were you able to fix it? The problem for me was, when I click photo the shutter does not close. It remains open.
tarafından
Yorum Ekle
Reasons range from mechanical faults to software. First check if it is adequately charged because this can cause mechanical issues. Also check if there is any obstruction caused by dirt, sand, debris etc.
If that's ok, then check if any software needs to be updated and if that doesn't work, reset to factory settings.
If nothing works and your warranty is still valid, return the %#*@ thing.
Puan 0
Yorum Ekle
Yanıtını ekle
wildan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 475
