Ana içeriğe geç
Repair guides for Microsoft's Surface Laptop Go, released in October of 2020.
Left my laptop overnight in cold car
Hi, I left my Microsoft surface go in the car overnight (11 hours) at about 0 degrees C (I think), and it won’t turn on… It was really cold to touch but now it’s heating up but won’t turn on. Can I fix it at home ? Or will it be broken inside ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
Hi,
Does it indicate that the battery is charging when the charger is connected to the laptop?
tarafından
@jayeff hi thanks for your answer, I haven’t tried plugging it in since I didn’t want to break it if there’s moisture inside, but will try now
tarafından
@jayeff it is charging yes
tarafından
@Penny Heslop-Pemberton
Hopefully it won't take too long but allow it to fully charge and then try turning it on, with the charger still plugged in.
tarafından
I would personally leave it in the house for 24 hours to gradually warm back up. It's not really the laptop, more the chemicals in the battery.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Penny, as @jayeff has said, let it charge, then try turning it on in a little while. The important thing about electronics that has been left in a cold (but otherwise dry) environment, is to let it slowly acclimatise (as in warm back up to room temperature) before doing anything. Blasting it with heat and such, is a sure fire way to let condensation form, and cause liquid damage to the boards inside.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Penny Heslop-Pemberton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 29
Son 30 gün: 143
Her zaman: 5,775
