Can I replace the keyboard - Surface Laptop 3?
I need to replace the keyboard on my Surface Laptop 3, is that possible?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hello, this can definitely be done, it doesn't look like ifixit has a specific guide for replacing the keyboard though, maybe you could use the opportunity to make one! The teardown video for this laptop on their youtube channel may be useful. You can find replacement keyboards online for relatively cheap from amazon or other similar sites. Hope this helps!
Bu yanıt yardımcı oldu mu?
I just did this on my surface laptop 3. There is a bit of surgery that you have to do. The old keyboard has a backlit sticker sheet on its back that you need to peel off carefully so that you can reuse it. And then you have to take off the metal shielding on the back of the mouse pad. The biggest pain is that there are about a hundred little rivets holding the old keyboard in place. You can pry it off and all those little rivets break off. It will completely destroy the old keyboard, but given that your replacing it it's not a problem.
Then you can put on the new keyboard and then re sticker the lighting sheet back onto the back of the new keyboard. Given that the rivets are gone, I used tape around the edges to hold the keyboard in place until the back was done. It is all working right now. Make sure to reconnect the two little ribbon connectors for the lighting sheet and the keyboard carefully.
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 75
Her zaman: 1,363
