Ana içeriğe geç
Google tarafından üretilen dizüstü bilgisayar serisi Chromebook Pixel'in 2015 versiyonu için onarım ve destek. Bu yeni sürüm, işlem gücünü ve pil kullanım süresini artırıp 2013 modeline yeni özellikler ekliyor.
Remove R/W screw to boot into Windows
I am looking to do a complete OS installation of Windows. I know the process of completing that through Mr. Chromebox installation guide. However, he mentions that you need to open the Chromebook and remove the R/W screw inside in order to fully flash an alternative OS such as Linux or Windows. Has anyone attempted this? If so, please describe where the screw is located? I know to open the Chromebook you just pry up the rubber pieces on the bottom. However I want to make sure I am only removing the correct screw on the inside.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I found a video on youtube showing EXACTLY what screw to remove. Wanted to share with the community. https://youtu.be/wOsezY7znZ8
If you need any help please feel free to reach out to me. I'll be giving this a try as well as performing the installation of Windows. Already have Dual Boot of Ubuntu/Chrome OS - due to no longer receiving updates I use Ubuntu ONLY at this point other than to run some terminal codes to install other flavors of Linus from ChromeOS.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Rickluebke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 415
