Ana içeriğe geç
Repair and disassembly information for the Logitech MX Master 3 wireless mouse. Released in 2019 and identified by model numbers MR0077, 810-006815 (Europe), 910-005620, 910-005647, or 910-005692.
Not working but green light is blinking
My Mx Master 3 mouse just run out of battery. I am trying to charge it, but it seems that there is an issue with the charging of the mouse. when I plug it in the charger, no lights blink (as usual), when I plug it out, it starts blinking green but in a strange pattern. Not the charging pattern, nor the low battery pattern.
Regardless of the green blinking light, I cannot access any of the devices from the bottom of the mouse and it seems to not connect to anything. My mac is saying that the mouse is at 5% but cannot connect to it like normal.
Open to suggestions
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
7 Yorum
Going through the exact same thing! Any fix?
tarafından
@theopyrillos @dvvvvv Could you guys describe the pattern? I have the MX Master 3 right here, but never experienced issues. Have you tried updating the firmware?
tarafından
let's say that when you charge it, you get a "breathing" light, that kind of smooths in and out. whereas in my situation is more of a pulsing light. unfortunately I cannot get it connected to anything to update and/or reset.
Spoke with Logitech Support and do not know about the issue. Their suggestion is to forget about getting it repaired.
I tried
- Leaving it to drain the battery and then recharge
- Fully charging it over night
- Installing Logi Options+
- Reset method from Logitech
nothing works.
The buttons do not respond to any action. The only action it responds to is on and off.
tarafından
i just sprayed some isopropyl alcohol on the power button switched it on n off then the lights turned on the 123 button. working fine now . mine started acting up after i charged it wouldnt turn on . till i sprayed it. good luck hope this help you out
tarafından
I have exactly the same issue... :(
tarafından
2 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Ok Fixed it now it can even connect to Bluetooth no problem.
I followed the instruction in this site how to open mouse disconnected battery for 10 minutes then reattached battery and it works again.
remove feet carefully and slowly and you can reattach no problem also one screw is a star type lucky I had the screwdriver. good luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
As a rechargeable mouse, batteries have a finite life. It may be the end of life of the battery. Reviewing the right sidebar will reveal procedures for disassembly and replacing the battery. This presumes the mouse wasn't damaged from liquids, dropped onto a hard floor or other ways to damage electronics within the mouse.
Puan 0
Yorum Ekle
Well I Will suggest you to check out the following video: https://www.youtube.com/watch?v=PfQ69PCc...
Puan 0
Yorum Ekle
It's not the battery because the it was 100% before this problem appeared
Puan 0
Yorum Ekle
I just had the exact same problem: green light was blinking and so did a white device 1 indicator at the bottom of the mouse. Resolved it by turning the bluetooth on my mac off and on again. Hope this helps
Puan 0
Yorum Ekle
Yanıtını ekle
Theodoros Pyrillos sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 64
Son 30 gün: 374
Her zaman: 10,111
