Why won't kick start move?
If I remove the spark plug, oil runs out and then it kicks over freely. Oil seems to be leaking into the cylinder and locking up the piston. How can I fix this problem and get the engine to start? Thanks for any help you can offer.
History• Edit• Delete• Add Comment
If the reed valve is stuck, can I drain the oil injection reservoir then add 50:1 mix and run the engine to free it up? Or do I have to replace the reed valve first? The oil leaking into the cylinder is from the oil injection reservoir. If I drain the reservoir, I think the kick starter will move again and then I can start the engine. Right? Will the oil injection system be damaged if I run with the 50:1 mix and no oil in the reservoir? Thanks again.
Bu iyi bir soru mu?
