What components are missing in the mother board?
Not sure if this is how it came or if it was removed but what is missing in this slot and where can i buy the item.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This looks like it would have been an optional upgrade for a dedicated graphics processor on some variants of this machine. The two smaller chips off to the side would probably be dedicated VRAM. They likely were never populated on this particular board.
As for where to find these chips, that's another story altogether. Depending on firmware it may be more difficult than just putting the chips on to get them to work.
Is there a particular reason why you want to install them?
Bu yanıt yardımcı oldu mu?
no reason just trying make sure i wasnt missing anything
@erickhdez1226 Perfect. Then as long as everything works fine, I suspect you're in good shape. It's totally normal for a board manufacturer to have one "master" circuit board that has several variants of what components end up on the actual product. Way easier to keep most everything the same if all you're doing is plopping a dGPU on there and any other components that are necessary for it to function correctly.
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 199
