Ana içeriğe geç
Phone is completely frozen.
The phone is completely frozen. No buttons work, touch screen don't work, the call time and clock is frozen also. What is the reason and fix for this????!!
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
@oldturkey03, there was really nothing to tell. I tried to power it off the conventional way. But as I said, nothing was working. Even the screen had frozen in time. However, I was able to do a soft reset by holding all 3 buttons on the right side off the phone until it powered down and restarted. It is now working fine. Thank you for your response nonetheless.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
@warlock1515 Glad you got it working again. Sometimes even the best software glitches :-)
tarafından
Yorum Ekle
En Yararlı Yanıt
@warlock1515 you are not telling us what you have tried. Also, is there anything you know off that may have happened to the phone. Anyhow, her are a few things that you want to try first.
REstart the device
  1. Press and hold the Power button (on the right edge) until the power menu appears then release.
Should that not work try this
Press and hold the Power button and Volume down buttons (on the right edge) for approximately 10 seconds or until the device powers off. If your device doesn't automatically power back on, partially charge the device then press and hold the Power button until the Motorola screen appears.
Let us know if this changed anything.
Puan 3
1 Yorum:
When gets close 2 full apps stop working outta the blue and freezes up. Just delete few apps don't use much. And log out first
I took peacock off and another. No more problems since. Moto g pure!!
tarafından
Yorum Ekle
Yes is broken screen touch
Puan 0
1 Yorum:
@hnvzuf6vkdisl2w sorry but no it wasn't. The OP stated that "holding all 3 buttons on the right side off the phone until it powered down and restarted. It is now working fine." It is important to read through the complete thread.
tarafından
Yorum Ekle
Yanıtını ekle
eric q moss sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 129
Her zaman: 5,517
