Ana içeriğe geç
Asus Transformer Pad TF300T, Nisan 2012'de piyasaya sürülen bir Android tablet bilgisayardır. Asus Transformer tasarımı, tableti bir dizüstü bilgisayara "dönüştüren" isteğe bağlı bir klavye ünitesi içerir.
Main charging ports have failed
After some time mine has stopped recharging and has gone flat.
The charger and cable seems fine when checking with a multimeter
When connected with the dock/keyboard it does not charge
When not connected with the dock/keyboard it does not charge
At no time do I recall any sign or smell of burning
How can I charge my TF-300 for further investigation into fixing?
Is there any way to charge my TF-300 through the USB-1 port? Like I have seen other devices charging through a USB-3 port?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@fuzzoffury according to the manual you can. "Charging through the USB port may take a longer time to complete. If your computer does not provide enough power for charging the ASUS Transformer Pad, use the wall outlet instead" Time to repair your charging ports :-)
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
There seems to be a misunderstanding
Can I charge into the usb-1 port on the opposite side from the port usually used for charging on the dock/keyboard?
No matter where the power is charging from?
tarafından
@fuzzoffury Your computer commonly only supplies around 500mA on the USB port which may not be enough to charge the tablet.
tarafından
Yorum Ekle
Yanıtını ekle
Mark Rienits sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 278
