How do I fix the power button
The power button has progressively become harder and harder to operate until it is completely impossible to turn the brush on now.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It appears you're not the only one with that problem; it seems to be common enough that there's even a YouTube video on the whole procedure of disassembling the unit and replacing the switch.
Philips Sonicare Elite Toothbrush Repair: How to Replace On/Off switch - YouTube
You'll need to be comfortable with a little soldering on a relatively small part mounted on the circuit board in order to accomplish this repair, though.
You might check around on some other videos for the part; although the comments state that you can buy the part on the person's eBay store, that store is no longer in operation. If you can't locate the specific part, it can still be found fairly easily just by measuring the length, width and height of the button in millimeters and putting that into a search engine, something like this.
6mm x 6mm x 3mm SMD push button switch
That's just an example since I don't know the actual dimensions of your particular switch. Pick one that looks as similar as possible to your existing switch in terms of the height of the button and the placement and shape of the circuit board contacts and you should be good.
Be sure and let us know what you find, that way someone else in the future who has the same problem can benefit from your efforts as well. Even better if you get ambitious and want to write your own guide here on iFixit!
Bu yanıt yardımcı oldu mu?
Thank you for this generous, and competent offer to guide me in my effort to fix my sonicare toothbrush. I followed the step-by-step directions on the YouTube video, and pretty soon found out that I have a sonicare of a different model than the one portrayed in the video. I did succeed in opening the handle (once I made up my mind that I would apply enough force without care for breaking it irreparably), and then found that the switch is embedded in a small electronic board, rather than soldered to it, well beyond my tinkering abilities.
I do not recommend opening the toothbrush. You can simply pull a 2 inch long shrink tube with or without adhesive (available in transparent or colored) with a diameter of 2 inches over the device and heat it up. This will last forever (or until the battery dies) and is dust and waterproof.
@philippi I'm confused. How does your advice help with a power button that's not working?
I should add that the button on my toothbrush was getting harder and harder to press because the rubber was starting to disintegrate. If a part in the switch is defective, my solution is of course useless.
@philippi Thanks for the clarification. Yes, I can see how that would help with a rubber button that's falling apart. Appreciate your contribution, Philipp!
Son 24 Saat: 14
Son 7 gün: 97
Son 30 gün: 466
Her zaman: 19,048
