Transmission has no up shift
No up shift from second gear
Bu iyi bir soru mu?
Is it an automatic? Most likely it's the Auto Trans Computer. A common problem throughout the 1990's built models. I've personally repaired thousands. Problem often starts with electrolytic capacitors and you can smell it. Leaking / exploding ones often pop the uP chip. Can also be the sensor, but you will need to measure to see if it's switching.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 504
Hi,
What is the year model of the vehicle?
jayeff tarafından
