Ana içeriğe geç
Apple tarafından Haziran 2004'te tanıtılan 20 inç, 23 inç ve 30 inç alüminyum LCD ekranlar. Sırasıyla A1081, A1082 ve A1083 model numaralarına sahiptir.
Adding a Fuse to Protect Display
The Apple power supply finally bit the dust, it was used on my 30" Cinema Display. I have purchased one of the $20 240 Watt, 10 Amp power supplies to replace it. I would feel much more comfortable using this inexpensive PSU if I could add protection between the display and the power supply. I welcome any advice on how to add a fuse with the goal of not destroying the display should the power supply go haywire.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
@charles218 lets see what the end connectors look like. You can always add a 25 V 8 A inline fast-blow fuse.
Bu yanıt yardımcı oldu mu?
Puan 0
6 Yorum:
I am planning on removing the connector from the dead Apple power supply and using it with the new power supply, this way I don't have to cut the display cable. It looks like the fuse would need to go between the recycled connector and the power supply tap.
tarafından Paylaş
@charles218 yup. Right one the power lead.
tarafından Paylaş
Is it important that the fuse holders wire be the same gauge or close to the same gauge as the connection wire?
tarafından Paylaş
@charles218 not on that length. You'll be fine with slightly smaller/bigger leads.
tarafından Paylaş
Old Turkey, you have been very helpful, thanks! I searched for the past half hour or so for 25 V - 8 Amps without success, nothing comes close, so if you or anyone has any leads on where I can find it, please let me know.
tarafından Paylaş
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Charles Larkins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 510
