Ana içeriğe geç
A1418 / EMC 3068 / iMac 18,1 / 2.3 GHz dual-core i5 processor. Released June 2017.
41 Soru Tümünü görüntüle
No display and no chime.
2017 iMac with display issues and no chime at boot.
1st 3 LED’s light up but the 4th LED will not light up and external display does not work either.
If the cables for the monitor are attached fan moves slowly. If I disconnect the cables and turn it on fan blows at full speed.
Is this a display issue or a logic board issue?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The fan is likely working correctly here. SMC controls the fan based on thermal sensors, so when you disconnected the display cable SMC went into CPU Safe Mode which will push the fans RPM.
With that said this series uses the integrated Intel graphics engine within the CPU. Sadly that part of the package failed. You need a new logic board.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you very much for the reply!
tarafından
Yorum Ekle
Yanıtını ekle
Infinus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 63
