Disassembled, now screws for cyclone cowl won’t go back in
It seems the screws are supposed to go through the cowl and the cyclone seal into the top body. They’re not going in because it seems they were never long enough to begin with. The pictures attached are with the screws threaded in the hole the minimum amount. With the cowl attached the screws aren’t long enough to thread in at all. I’ve tried pressing down on the cowl as I screw in, and videos don’t seem to have this problem
Bu iyi bir soru mu?
5 Yorum
Hi
Have you got the alignment for the cyclone right?
Also are you using the right screws as there are a verity of screws used across dyson models
HelloMacOS tarafından
@hellomacos I believe so, it sits fully in only that orientation. The screws are from the vacuum which is why this perplexes me. I can’t figure out what I’m doing wrong
M J tarafından
@meantomatoes
Do they just get overly tight halfway?
@hellomacos No, they just spin. But I don’t think the threads are stripped, the screws literally don’t seem long enough to reach the threads under the cowl and cyclone seal.
M J tarafından
@meantomatoes
I wouldn’t think they were stripped ether,the posts would crack before that
Maybe be try another screw from another part of the cyclone
